Hi I have an MRV1507 with output issues on the bench,
the amp powers up and idle's fine,
with the input switch set to 1+2 mode it plays clean audio on both channels.
with the input switch set to stereo mode it only plays audio on the right channel and very low on the left, there's very low audio bridged.
Idle becomes erratic on bridged mode.
with the switch set to mono there's very low audio
I've already checked the amplifier board for dry joints and run solder on any suspect joints with no change.
any support with this appreciated
thanks
thanks
