Next on my to fix list.
What I know so far:
Gate resistors to all the FETs are all good measuring just under 98 ohms. All FETs removed as two were definitely dead. 110 ohm resistors from the 494 to the FETs also good.
Chassis ground trace was blown so I've replaced it with 16 gauge cable.
Outputs, I think two channels have shorted and the other two seem to measure OK. Will take them out and measure them again to make certain as it's been too long since I last worked on the amp.
This amp uses 2SD718, 2SB688 outputs. If there are shorted channels as I suspect, would sanken 2SA1186 & 2SC2837 be suitable replacements? Also, would it be wise to check the driver transistors for those channels too?
What I know so far:
