Got this amp in needing all (2) new power supply fets. This amp uses two IRFZ48s.
I think I can use IRFZ44 for testing as I have some of those, but I also have a bunch of matching IRF3205 fets. I know the Z44s are ~15A less powerfull than the Z48s, but the IRF3205s are ~15A MORE than the Z48s, which tells me that IRF3205s might be the better choice. This amp has 4 larger output transistors and might benefit from the added power if it will work.
Would IRF3205s work with or without modification?
Thanks!
Thanks!
