Ok like an idiot I managed to short out an output transistor which took out the channel
I replaced the irf9540 and irf 540 transistors, 2 of each.
I powered it up and it appeared to work until my in line fuse blew.
The sound became distorted and the transistors were hot.
I have replaced them again, powered up and the fuse blew again. This time I used a 10 amp fuse to minimise damage.
The amp is a mrv1005
Help appreciated thanks
