I'm going to build a pair of Frugel-Horn Mk3s with Alpair 7 drivers. For budgeting reasons, I'll be obtaining the drivers now. However, it is likely that I will be moving to another country in the beginning of next year, so I'm considering to use the drivers in a kind of throwaway enclosure or baffle at first, so I don't have to ship the largish horn cabinets around.
What sort of temporary enclosure could be recommended? I'm interested in trying an open baffle, if it makes sense for these drivers. What would some OB good dimensions be?
– Note that I don't have easy access to woofers, so these will be single-driver only.
I'm also considering mounting the drivers in a bottle or cylinder, creating a makeshift ported cabinet, if I can find something that fits. (The idea is from this thread: http://www.diyaudio.com/forums/full-range/79721-tangband-w3-871s-bottle.html
Any ideas most appreciated! Thanks.
How about these?
Pensil 7 for Alpair 7
the link is to the plans from the planet10 website. i think the design is by Scottmoose (please correct me if i am wrong)
cheers,
mymindinside
cheers,
mymindinside
How about these
Of course, you could also try them or a large-ish open baffle (cant get simpler than that)
mymindinside
Indeed, while somewhat limited to maximum SPL and bass extension vis a vis the FH3, the little sMarS is quite an eye-opener.
Sounds great with as little as 3-4w or so of tube power, and my son i really happy with his pair on Virtue one.2.
