Alpair 7.3 in Alpair 7 Pensil enclosure
One of my Alpair 7 EnaBleD driver developed a rubbing voice coil. Unfortunately, I could not find a replacement and had to buy a pair of 7.3 drivers (thanks to a number of people on this forum for pointing me in the right direction).
Can I get way using my old Pensil enclosure by suitably changing the amount of stuffing? If so what is the recommended amount?
Many thanks in advance.
Best,
Giulio
It is within limits (i.e. it's not a free-for-all; don't try ramming dissimilar drivers into them and expect it to work). However, the 7.3 should go in acceptably; the alignment will change a little, but it will be functional. Beats building a new set of boxes.
Thank you both! Should I expect to have to reduce or increase the amount of stuffing? In the latter case, I'll have to buy it in order to experiment.
