I have Alpair 7.3s drivers in Frugal-Horn 3 enclosures powered by a pair of diy SE (Mullard) valve amps (3.5 watts per channel). Should the Alpair 7.3s be connected to the 4 or 8 ohms taps on the output transformers? The published impedance of the Alpairs is 5.4 ohms.
The present connection is to the 8 ohm tap and switching to 4 ohms will be a re-soldering job.
Sorry if this has been covered before.
