Hello,
Well, I’ve yet again pooped up with a cabinet, my ADHD gets the better of me and the thing changes direction with every new idea I see..!!! Currently I have a pair of cabinets with the intention to use alpair 10p’s I was following the Woden Simple Reflex ov9 but wasn’t too keen on the tall and skinny look..!! Sooooooooo I have made attempts to go a little shorter and longer. My internal measurements are
200mm wide / 335mm high / 300mm deep. I have 2 x 50mm x 120mm ports.
Without bracing it is 20.1L with bracing it’s approximately 17.9L
Driver (centre) position is proposed at 110mm from internal corner and I was planning to place the port in the rear approximately 60mm (centre) from bottom internal corner.
I’m also open to building larger bookshelf boxes, not sure if I’m looking in the right places but they all seem rather compact.
I would also like to try a compression driver and horn a top this beast if it ever gets past the…. If it ever gets built..😝😝 just copped a peek at the Sinjisu Audio super hiro, mind is drifting towards something like that..!!
Im very aware that I’m asking a lot for someone to do the calculations on this but please could someone that is a bucket load smarter than me, ideally does not have ADHD ( 2 ADHD’ers on a project is a race to the bottom), and is generous enough to help, please provide me with some sort of encouragement that this will work or is it firewood..??!!! Lol
Can’t tame the neurological diversity that is my brain..!!!
Cheers.
Cheers.
It is a reflex so except for baffle effects from the baffle size, you can play with the shape as you like, just maintain volume & vent size
dave
dave
You'll only need 1 port @120mm long for ~47Hz Vb in a 17L box, allowing .9L for driver & vent volume (I'm guestimating). You can do the math. 🙂I have 2 x 50mm x 120mm ports.
jeff
Thanks Dave & Jeff.
@vinylkid58 1 port per speaker, 2 ports total is what I have but I see how it reads..!! I was likely distracted by something else 😝
That's a constant for me as well. 🙂I was likely distracted by something else
jeff
