Hello people. My brother has an Allnic H3000 phono stage that has just given a fault. It 'isn't receiving current to either the left or right outputs'. The psu would appear to be working
It has some current meters on the front and they are both low/zero. He said if it was a valve going down it would show on these....not sure what that means.
Does anyone have experience of these things....a schematic.....know a good service tech that could look it over?...or indeed where to start checking things.
I don't know much about vinyl set ups....I asked if it could be that isn't getting a signal from the turntable to which he replied that may point to a faulty cartridge and that that is unlikely....but I'm guessing it could be wiring in between an issue too maybe?
Any advice appreciated ��
Each channel has a meter , the needle should be in the center of the two parallel lines to the left of centre on the meter face .
If the meter needle is to the LEFT of the lines it means both or one of the E810F valves is faulty .
If the needle is to the RIGHT of the lines then one or both regulator valves is faulty.
Thats thec FIRST check.
