I know that the Aleph 5 is dissipates 150 watts, can i just adjust R19 to 100 watts at idle?
B billy Member 2001-12-26 3:42 am Hong Kong 2002-09-17 5:49 pm #1 2002-09-17 5:49 pm #1 I know that the Aleph 5 is dissipates 150 watts, can i just adjust R19 to 100 watts at idle? ••• More options Share
V vpharris Member 2001-12-14 6:30 am Philadelphia 2002-09-17 6:09 pm #2 2002-09-17 6:09 pm #2 Probably, but here's a real good thread that discusses optimization of an Aleph 5, with lots on the biasing: http://www.diyaudio.com/forums/showthread.php?s=&threadid=3589 Of course, the idle power is simply the idle current times the +/- rail-to-rail voltage. ••• More options Share
S skaara Member 2002-06-30 1:23 pm Europe, Slovenia 2002-09-17 6:46 pm #3 2002-09-17 6:46 pm #3 Yes you can. That will change the sound of your amp too.. ••• More options Share
F fcel Member 2001-09-02 7:42 pm LA County 2002-09-17 7:45 pm #4 2002-09-17 7:45 pm #4 In case you're not aware of it (mentioned on this forum quite a few times) .... more bias current ... more heat ... better bass ... which is what we all want, isn't it? ••• More options Share
Nelson Pass The one and only Paid Member 2001-03-29 12:38 am 2002-09-17 11:19 pm #5 2002-09-17 11:19 pm #5 That's 150 W per channel, right? ••• More options Share
B billy Member 2001-12-26 3:42 am Hong Kong 2002-09-18 4:25 pm #6 2002-09-18 4:25 pm #6 Nelson Pass said: That's 150 W per channel, right? Click to expand... More bias current ....more heat....better bass___More Money!! Little bias current ....little heat.....little bass____Little Money!! HA...HA...HA...HA !! ••• More options Share
