Hi All,
I have created a pc-board layout of the Aleph 30. The layout assumes that I have decoded the schematic correctly!
If you have a spare moment, I will appreciate you looking at my schematic, to see whether it is accurate. I am not completly sure where some nodes should be, and where not.
An image of my schematic is here:
http://www.owf.co.za/chris/pass_labs_stuff.htm
There is also an image of my pc board layout.
Thanks,
Chris
Thanks,
Chris
hmmm
I can't see that you input dif. stage drives anything....... The signal doesn't go anywhere from between Q1 and R14
Ergo
Ergo
Nice job ChrisV!
Creating some extra space for the heatsinks was indeed necessary since I also struggled with Mark's original Aleph 4 board.
Please show us some pictures when you've finished your creation.
Leroy
Leroy
I build it.I am not satisfied with sound.It is interesting. Changing the feedback resistors (R3,R7) changes the sound.It has more mids and whole sound is not so "slim".
Nice layout for the Aleph front-end. However, attaching the back-end/output devices via hook-up wires could cause oscillation problems generally in amplifiers with MOSFETS as output devices. Is this not a problem with the Aleph designs?
