Hi guy`s
Maybe some one can help me on this one. After a few weeks of listening of my monoblock`s it seem`s that I have a problem and no idea what caused the problem. Firs day of listening I was using CD player directly conected to the input of the amps. No hum no buz, no problem turning the amps on. After a few days I conected CD on the amps via preamp using single ended conection. Audiable bot not very loud toroid freq. buz (did not use shorting plugs) from the speakers. When I made my xlr conections and pluged them in there where almost silence. About three weeks there where no problems except one bad ground conection which was taken care of. Mesuring during days, showed all basic values on the boards in limits. Few days ago I noticed the litle pops and like bad ground conection noises when amps was turned on. After a few minutes of warming amps on, those interuptions stoped. Yesterday I thurned on first chanal went to the second and thurned it on and after 5 sec. a had the room fol of sound like somebody disconected main ground wire. After few second`s ewerything stoped. Boath my monoblocks where death-switched off, without the power???. I thurned the switches off, checked out all conections and parts in turn off position.... Found blowen fuse on one chanal and that is all. Than I thurned on unconected(cd, speakers) amps one by one, meshured basic parameters on boards, off set on output and everything was normal. Conected CD directly to the amps turned them on and they where playing. I thought that I coud have a problem with balanced output on preamp so today I conected preamp with SE conect. And ther was a buz audiable 5m away from the speakers (much louder then in the first days of listening sesions). Tryed directly CD player, no buz. I opened amps and foud what I missed yesterday - blown thermistor TH1 (main plug to ground). Coating of thermistor was cracked but amp was still playing. I was using NTC 10A/5ohm (buerklin), TH2 and TH3 same walue paralel on mains. (BTW - guy`s in Europ - what typ of thermistors are you using)
PSup. - 1,5kW toroid 33+33 per ch, 136.000uF. (Wireing in ZIP file)
All on board parameters are still normal, but something must be wery wrong. I know that it is hard to give any sugestions based on this kind of report but I hope that someone will have some idea. What to check, what to do?
thank`s on advance
regards - Marijan
thank`s on advance
regards - Marijan
