Hi all,
I'm going to build a Aleph 5 and start to collect parts. Any good suggestion on PSU caps?
Thanks guys,
The TS-HA series is going to be discontinued. Can anyone point me to where I could source them.
Actually whatever can provide full body sound with deeper bass will do. I like rock music.😉
albertli said:Thanks guys,
An Aleph 5 might not be what you want.
Only 20mm diameter cans were discontinued. The sizes required for Pass amps typically have 30mm+ diameter cans and remain in production. Digikey have 2000+ TSHA 10,000uf/63V in stock for instance.
MikeW, Do you mean the Aleph 5 can't rock? Would like to listen more.
Aleph amps have a great midrange and highs, but their strength is not bass. If you want bass build a X100 amp or Krell clone.
Or build both and bi-amp.
aleph
I will second that nomination for a KRELL...if 50 watts is enough, you cannot beat the low end of the KRELL KSA-50. All the information for building one is on the DIYAUDIO wiki page.
Re: aleph
Thanks for the advise.
50 watts Krell will be perfect, but I can't locate the wiki site through search engine. Would you point me to the said site. Thanks
MikeW said:Aleph amps have a great midrange and highs, but their strength is not bass. If you want bass build a X100 amp or Krell clone.
zlast said:I will second that nomination for a KRELL...if 50 watts is enough, you cannot beat the low end of the KRELL KSA-50. All the information for building one is on the DIYAUDIO wiki page.
I have some extra 68,000 uF caps leftover from my Aleph five project I may sell. Drop me an email.
Merry Christmas,
Dan
Merry Christmas,
Dan
Dan,
Thanks for the offer. What is the volts rating and brand with your caps. I need something 63v minimum.
What I need is something 20,000-30,000uf, but I don't really know what different it will make on sound with bigger capacitance. ( between the 20,000uf and 68,000uf ).
albertli said:Dan,
Merry Christmas,
Dan
- Affordable best caps for aleph 5 - PSU -
