Hi guys.
Got a good price on the faital pro 8fe200 so... I bought 4! Then I bought 2 faital hf100 compression drivers along with the sth100 tractrix horns (70 vert x 80 horizontal coverage)
I would like to try a pair of high efficiency MTM (vertical) setup with these or more like a WCW!
I've read that driver spacing should be based on crossover point and the closer the drivers the better. With the sth100 horn between the two 8" woofers there's 6.5" center to center, which (I think) is close to 2000hz, if I'm right this seems a good point to xover based on frequency response charts of the woofer & cd and in general. Am I right? Would this work well?
I intend to use a pair of (Bill Fitzmaurice) Tuba 18 subs with those MTM's crossed at around 80hz'ish. 80hz and probably lower too seems possible based on what was shown in winisd.
Btw I would be using an active crossover (cx2310)
Any advice, any thoughts on using these drivers in an mtm configuration? Thanks
