replacement amps
The XOs on these are probably fine. I'd think about replacing the amps with some gain-clones -- http://pub4.ezboard.com/ffakeidsfrm1
dave
paulb said:These ones came with the amps pre-blown, apparently it'sbeen a real problem with this pair. Your comment confirms my thinking: I'll look at replacing the internal amps.
Thanks for the info.
dave
Thanks. XO means crossover? Just opened up the cabinet, supply is +/- 50V, a little high for chip amps.
Interesting discussion group there.
The link seemed funny (I typed it in and found it). Let me try it here:
http://pub4.ezboard.com/bfakeids
Hmmm, seems okay in the preview window.
paulb said:Thanks. XO means crossover? Just opened up the cabinet, supply is +/- 50V, a little high for chip amps.
I'd look at that as an opportunity to change the power-supply to choke input ... but it is probably easier to find an amp board kit that uses 50V.
The 100W AKSA uses 49-0-49. 100W for a tweeter is a bit of overkill thou.
You could use the existing PS for such a unit, and put in another supply for a gain-clone for the tweeter.
dave
- Advent Powered Loudspeaker?
