Hi.
I have a Weilang Dac7 with USB and coaxial input. It only has a "dummy" optical connector. It seems like it was an optional feature and I did not explicitely ask for it when I bought it 10 years ago. Or maybe they "forgot" to set it up? 😀
I guess this is not an easy task but in case it was not so, could I wire the connector to make it work? It has a WM8805 spdif transceiver and I was reading this is then doable.
I gather I need the proper voltages from the PCB and I see there are +/- 3.3V. Where should I get the signal from? It already has got a switch to choose between USB and spdif input.
I think I found the schematics on the web but I do not know whether it is allowed uploading it here.
Thank you!
Thank you!
Gee, without having it in front of me I would have no idea. Best if you have a service manual including schematic for it. Otherwise we would need hi-res pics of both sides of the PCB (or PCBs if there is more than one). Pics need to be good enough to be able read part numbers, etc.
😀Gee, without having it in front of me I would have no idea. Best if you have a service manual including schematic for it. Otherwise we would need hi-res pics of both sides of the PCB (or PCBs if there is more than one). Pics need to be good enough to be able read part numbers, etc.
You can see the schematics in the Markw4 post, after yours. Thank you, I will take it apart but I should wait for a while because I'm already fixing my amplifier and I do not want to have too many bits around
Thanks! That's exactly the schematics I found. I will give it a read because it seems there's a lot of stuff. But I will need to translate it, first
