I've build a portable speaker box with a sure electronics jab2 board. When I use the built in Bluetooth or line-in I get a max volume of 89db (Not loud enough for my liking).
When I use a Google Chrome Cast audio through line-in, I get a max volume of 98db, so about twice as loud!
So how can I improve the standard line-in and Bluetooth signal?
Could I buy one of these small NE5532?
NE5532 AMP DC/AC 12v~15v Audio OP Preamps Hi-Fi Pre-Amplifier Board PHILPS | eBay
I'm using a Samsung S8 if you're wondering, plus I've used multiple devices including a pc with all having the same result.
Thanks in advance.
Thanks in advance.
Should work, set it up for a gain of 12dB (x4).
Cheers for the reply.
Awesome, will I lose out on quality?
I guess the Chrome Cast has something close to x4 gain but the quality is still good.
Give it a try and see, it doesn't cost much.
That's a good point.
Thanks 🙂
Hi, I have bought 3 of those to date & none have worked. better to use one of these
Pre-Amp RCA Input / Output Line Driver Signal Amplifier Car Stereo Radio 12vDC | eBay
Cheers
Hey,
Damn just brought one.
So it had no change at all?
I'll probably just give it a go then try out the one you suggested.
Cheers
