For start I wanted to say a hi to all.
Now.
As title says
I want a SINGLE ANALOGUE input which can do up to 100KHz FLAT.
Then I want this analogue signal to put it into a ADC.
Than, I want to take it out from IP (NET).
On the other side of the NET (IP) there will be a IP to DAC where I could take out this signal as it was (up to 100KHz flat) BUT without much latency.
Simlified, I want a single analogue signal from 0Hz up to ~100KHz to pass it through a NETWORK.
Is it posible?
Thanks in advance,
George.
Now.
As title says
Is it posible?
Thanks in advance,
George.
