adapter?
If I were doing this I would procure some octal tube bases. Either salvaged from old unwanted tubes, or buy new one like these.
http://cgi.ebay.com/Vacuum-Tube-8-P...ryZ73375QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Then I would get some 5 pin sockets to fit the 807's, and using short solid copper leads soldered to the 5 pin sockets, mate them up to the tops of the octal bases. The only tedious part is making sure the wires go to the correct pins in the octal base. And this, of course, assumes you are deft with a soldering iron.
I actually made adaptors like this with 4 pin bases years age for testing purposes. A little gorilla glue helps hold them snug.
edit: I forgot to mention that you'll have to drill a small hole in the side of the octal bases for the plate lead. I'd use Belden test lead wire for the cap. Or teflon coated silver plated wire if you're of that persuasion.
Victor
