Hi 🙂
I read that the voltage for the AD8620 is +-5 to +-13V, but I would like to use it for replacing some opamps which work with +-15V
Do you think I will run into problems with this? Will it blow?
Do you have any recommandation for a good dual opamp?
Any other idea?
Any other idea?
I think that OPA2604 fulfils your expectation. Look at Analog Devices home page for data & application notes
http://www.analog.com
pop peranders: my opinion about them is "hit me baby one more time!"
I think I will try them, and if it smokes, that's life 😉
pop mandat: OPA2604 is something I never tried. Any idea how it compares to the AD8620?
push me: thanks for your feedback 🙂
I have used OPA604 as a driver followed by four pairs of 2SC3944/2SA1535 transistors working in my A class headphone amp. It sounds really great. Due to the large output current OPA604 works very efficiently in output stages. When you need less efficient op-amp try OPA132. Both op-amps are similar in terms of the sonic quality.
Some information about sonic quality of the most popular op-amps you find below.
http://tangentsoft.net/audio/opamps.html
great link... thank you very much 🙂
I will use them just after the DAC, so I don't know if your case is the same with mine.
What do you think? 😕
A kind of op-amp used is determined by an application. In The First MkII, which is a DIY DAC, in the output stages (after DAC unit which comes from Crystal) OPA637 and BUF634 op-amps are used and good sound was obtained.
I had some 2604 to play with, and compared them to OPA2132P in +-15V environment.
I like OPA2132P better. More details... Maybe this has something to do with the high gain for the OPA2132P.
Anyone experienced something similar?
Ok people... The AD8620 is inside.
It sounds amazing compared to what was there before. I really have no words to compare it. It's brilliant!
As I have some AD8066 around I did a small test, A/B/A/B
At first I tried with AD8066, it sounds very good as well, just that I like AD8620 better. 8620 may not have the dynamics of the 8066, but sound more natural, closer to reality I would say.
Both of them were used with +/- 15V, which, especially for the 8066 is quite a bit over the specs(+/- 12V) so this might have influenced the result, don't really know it.
What I liked about both of them is that they are really silent. Dead silent, no noise. Point.
Another remark: the 8066 got quite hot
while the 8620 is hardly warm so I think I am on the safe side of the road with it(it is rated at max -40 to 125C).
greetings to all
greetings to all
- Design & Build
- Parts
- Ad8620
