Active system
This is from the link you provided, Audio section:
Audio line in minijack (digital/analog)
Audio line out/headphone minijack (digital/analog)
That means you can get S/PDIF digital audio out via toslink, with an adapter like this one:
https://www.thomannmusic.com/the_sssnake_adapter_toslinkmini_plug.htm
Is it correct that your speakers contain a MiniDSP PWR-ICE amp? If so, those have AES/EBU digital inputs. You'd have to convert the optical signal to AES and connect that to the speaker's digital input.
If your MiniDSP device is anything like my OpenDRC (same company), the DSP will resample all incoming signals to its internal clock.
In this case, because of buffering and reclocking, there is zero difference between an S/PDIF signal from the Mac converted to AES/EBU and an AES/EBU signal from an external interface.
A board that converts the optical output of your mac to AES will set you back about $20, USB audio interfaces with AES output seem to be quite a bit more expensive.
Joined 2007
Yes they are much more expensive. I’ve opted for a Topping D10s. While it’s nothing special it has a spdif output and a usb input and for $109. I considered several different options but it came down to just realizing not only what you said but also my source will likely change in the not too distant future.
I do appreciate your input
Jcris
Joined 2007
I really wanted to avoid any additional dac to adc jumping around. Fortunately the speakers can be used with aes or spdif. I was really having trouble justifying an aes solution which was quite a bit more expensive. So I opted for Spdif, maybe not ideal but workable and much cheaper. I’m planning on changing this setup when I get a reliable wifi connection. At the same time I’m also looking for a streamer which has it’s own set of complications.
Thanks for the reply
Jcris
