I have old active 3 way speakers with one of best mids&highs i have ever heard.
The bass is not so good.
Crossover section for the bass is 45hz to 400hz.
If i play them loud (the max) the bass gets distorted& muddy. Also the bass woofers are so old (40 years) that they breakdown every now and then. They simply cannot handle the power.
I want to replace the bass with modern woofers using the original active amp. There is three separate amps for bass, mid&highs.
Everytime its said that if you replace the original driver with another one, you need to change the crossover too.
So first, if i use l-pad attenuator for getting the levels right
And secondly make a new enclosure for the new bass driver according to its specs and for adjusting the time delay.
Why wouldnt it work in this case?
