The amplifier outputs voltage, it doesn't care about speaker impedance as long as it isn't too low. 4-ohms or above is fine for most amps, so your speakers should work okay. They may need to be adjusted to different volume levels compared to each other depending on their relative efficiencies. That should not be a problem to do in the minidsp.
