Has someone ever tried to use active x-over as RIAA equalizer?
I use one such,( running active two-way system) namely Alto Maxidrive , and of course there is out plenty of them, all Behringers and DBX's and so on, but the question is: most such devices has easily enough EQ power to make RIAA curve. One could possibly need line pre or step-up tran between a xover and a cartridge, but is there some window to aim, to make A/D converter to work in 16-bit or perhaps even 24bit and not yet saturating ADchips with RIAA.s uncorrected tr3eble emphasis? complicated, ehe? Yes , I think so but I also think that could be something to at least to try, namely, if you already has one such device (Active xover, that is if you are usin active multiway system with such device) so why not to try to skip separate RIAA preamp with it, if possible., or replace it with just line pre. Help with maths please? How much one could boost carts signal before ad-chip begins to clip, and does it seems possibe to achieve reasonable line level takinf into account chips sample rate and dynamics? ...
Mika
Mika
