Im new to home theater and apparently have already committed the cardinal sin of buying Bose speakers. At least I bought a used set of Bose Acoustimass 15 and paid about one quarter of the price of a new set. I also bought a Yamaha RX-V2500 receiver (130 w x 7). Is it possible to use the Acoustimass subwoffer w/o using the special wiring that came with the speakers. My room is already wired with standard speaker cable and I would like to us ethe Acoustimass subwoffer with the standard speaker wiring. If this is not possible, could someone recommend a subwoofer that would work well with the Yamaha receiver.
Thanks,
db113
Thanks,
db113
You can probably use normal wiring with the Bose subwoofer, but I don't know if you would need to modify it.
You could build yourself a nice subwoofer! 😉
db113 said:I Is it possible to use the Acoustimass subwoffer w/o using the special wiring that came with the speakers.
Just looked at the B*$e web site & found their Acoustimass 15 manual. Looks like you should just be able to plug in the RCA jack on the funky cord to the LFE output on the receiver, but you will need the cord from receiver --> sub (or cobble your own for the LFE).
Good luck!
BTW, don't worry about the "sin". I stumbled across diyaudio a couple of years ago when I was looking to buy B*$e, 'cuz of course they're the best . (But not before I'd spent $300 on some other speakers that are now acting as doorstops).
mk
P.S. - The individual double cube speakers go for $75 - $150 each on ebay... If you liked the sub, you could keep it, sell the cubes!
Link to manuals: B*$e manuals
The bose sub and speakers pretty much go together, because the subwoofer probably has high pass filtering for the cubes so that they don't start to sound like they're farting, and then catch on fire at high levels.
the "subwoofer" is actually not techinically a subwoofer because of its frequency range. that is why its called a bass module by bose.
it will play very high as it doesnt have an adequate crossover for a subwoofer. so, you will get voices through it unless you send it an appropriate bass signal from the preamp or whatever.
you might be best off selling it all and doing some DIY (i assume that's why you are here).
cowanrg said:the "subwoofer" is actually not techinically a subwoofer because of its frequency range.
Neither are most so called subs on the market
that is why its called a bass module by bose.[/B]
One of the truest things they have ever said to their customers.
it will play very high as it doesnt have an adequate crossover for a subwoofer. so, you will get voices through it unless you send it an appropriate bass signal from the preamp or whatever. [/B]
Pretty awful isn't it?
you might be best off selling it all and doing some DIY (i assume that's why you are here). [/B]
Now there's some sage advice.
DIY, DIY, DIY,
Cal
i once thought of getting one of the passive bass moduals on ebay and adding a plate amp to see what would happen...
oh oh i just remembered, something...
back in '95 or '97 or something, my aunt got a adcom preamp, amp, amd cd changer, and a bose acoustimass 2.1 system, she asked me to hook it all up and so i did... it sounded all right till i put the bass outlaws
"illegal bass" cd in the player. i in my entire life have i ever heard that much distortion at such a low volume. i barely turned up the volume and it sounded like a a bunch of fast farts... put culture club in and it sounded all right again, bass outlaws, crap... i left so sickened
sid216 said:i once thought of getting one of the passive bass moduals on ebay and adding a plate amp to see what would happen...
A buddy of mine inherited one, we did just that with my PE plate amp. IIRC It was the 2.1 system, there were no surrounds or place on the 'module' for them.
Horrible dips and peaks with a slow sine sweep. Sounds like its bandpassed by enclosure or passive xo.
Well, the Intellexual.net review looks at the S&V freqency response chart and says there is a -10dB hole between 200 and 280 Hz. I don't think that's exactly true, because we don't see a resultant summed frequency response, just the response of individual parts. The hole is probably more of a 'dip' than anything else. However, that does not redeem the Bose system from its other undesirable characteristics.
Oops, I'm sorry for referring to the Bose bass module as a "sub". I should just call it a "B.M." for short.
My suspicion is that summation isn't going to fix a lot of that. I guess I would call that more of a suck-out than a dip. Maybe it is a matter of semantics. I guess one could blame the satellites for not having enough low end extension. Either way, it comes down to poor incorporation of the components.
Two speakers outputting at the same loudness at the same time is equal to +3 dB gain.
So that valley is -7 dB. -7 dB is HUGE.
About 40% quieter sound in that area.
Re: Re: Acoustimass 15 subwoofer
Oh, man. Way back when I worked for a speaker manufacturer, we got samples of the Bose cube "drivers" - we could land them in Canada for $0.50 a piece per 1000 units. We had a good laugh at the time.
Kinda breaks one's heart now though...
m
m
The best use of a bass module is tossing it into a warm freshwater lake or pond and hoping some fish make it thier home.
what i wanted to do was prety much the same except pull the x-overs and hook the amp up directly to the drivers ( if you want to call them that), im sure the impedence would be a factor though. any one know the Z of each of the bass moduals drivers? or better yet a color photo of a cut away of the in sides? that would be cool too...Cyrus_s said:
Tweeker said:The best use of a bass module is tossing it into a warm freshwater lake or pond and hoping some fish make it thier home.
you mite have something there 😉
for a sub, do what i am planing on doing. Atlas 15 7cubes net tuned to 18Hz after bracing, port, and metal sheeting inside to lower Fs of the enclsore walls. expecting it to weigh over 100lbs 😱 but also give good responce down to 15Hz which is plenty for most movies.
or you can do us all a favor.
Get an Adire 18 Tumult. Fs of 15, yes 15, Hz. probably capebale of a good respince down into the single digits with a large enough enclsore...Adire pwnz...
CBFryman said:for a sub, do what i am planing on doing. Atlas 15 7cubes net tuned to 18Hz after bracing, port, and metal sheeting inside to lower Fs of the enclsore walls. expecting it to weigh over 100lbs 😱 but also give good responce down to 15Hz which is plenty for most movies.
At ~750 for a single Tumult 18, one can afford almost two Av18's. I'd take 1100L for 50 bucks more over 560L displacement.
- Subwoofers
- Acoustimass 15 subwoofer
