Does anyone know if the bass drivers in the Acousticplan Veena are the Beyma 10BR60? The frames look the same, although the magnet looks a little bigger, could be a cover though.
6moons audio reviews: Acoustic Plan Veena
HiFiForum.nu - High End 2008 - Häng med på Munchen mässa
I am looking to build something similar, I have the Veravox drivers (on there way here atm), although they are the 5S rather than the 5X in the Veena, and looking for some 8"/10" drivers that are quite cheap for the OB.
Both the 8BR40 and 10BR60 seem to sim well in OB (xbaffle) and should be more than enough for my room with 4 each side.
Got a Decware Zen build on the go for the Veravox, will use an active crossover as well.
Well the Veravox drivers are here:
Veravox 5s by RSdesignUK, on Flickr
And plumed into some old temporary cabinets that were designed for the 5S in Bi-Pole configuration
there is some information about the veena construction in that pdf 😉
www.acousticplan.de/Dagogo_Veena.pdf
Oh cool, had searched all over the place but not found that.
Seems they are the Beyma drivers then.
