Hi
i am selling a pair of AE TD15m 4 ohm in good condition , see photos .
i bought four of them used but ended up using only two .
asking $560
price includes shipping within the conus and paypal fees
TD15M-4ohm
Fs: 34.7Hz
Qms: 5.09
Vas: 312 L
Cms: .3 mm/N
Mms: 70 g
Rms: 3 kg/S
Xmax: 6 mm(peak)
Xmech: 10 mm(peak)
Sd: 855 sqcm
Vd: 1.02L (p-p)
Qes: .35
Re: 3.2 ohm
Le: .2 mH
Z: 4 ohm
Bl: 11.81 T/m
Pe: 500W (cont.)
Qts: .33
1WSPL: 97.7 dB
2.83V: 101.7 dB
asking $560
TD15M-4ohm
Fs: 34.7Hz
Qms: 5.09
Vas: 312 L
Cms: .3 mm/N
Mms: 70 g
Rms: 3 kg/S
Xmax: 6 mm(peak)
Xmech: 10 mm(peak)
Sd: 855 sqcm
Vd: 1.02L (p-p)
Qes: .35
Re: 3.2 ohm
Le: .2 mH
Z: 4 ohm
Bl: 11.81 T/m
Pe: 500W (cont.)
Qts: .33
1WSPL: 97.7 dB
2.83V: 101.7 dB
