Hello
About the SRC4192
In bypass mode, do the signal still pass through the interpolation filter and do the SRC clock still control it ?
It's not clear about that in the data sheet.
Thank you
And merry Christmas to all.
Gaetan
About the SRC4192
Thank you
Gaetan
Looks like the data goes un-touched in the bypass mode:
BYPASS MODE
The SRC4192 and SRC4193 include a bypass function, which routes the input port data directly to the output port, bypassing the ASRC function. Bypass mode may be invoked by forcing the BYPAS input (pin 9) high for either the SRC4192 or SRC4193. For the SRC4193, the bypass mode may also be accessed using the BYPAS bit in Control Register 1. For normal ASRC operation, the BYPAS pin and control bit should be set to 0. No dithering is applied to the output data in bypass mode, and the digital attenuation and mute functions are also unavailable.
Hello
Yes, I was meaning that the dac chip become kind of non-os.
I presume that wen the SRC are bypass, it's the spdif signal through the receiver chip, who give the clock an not anymore the SRC ?
Thank
Bye
Gaetan
Thank
Bye
Gaetan
The clock will be the one from the SPDIF receiver, recuperated from the SPDIF stream.
The DAC will be OS or NO-NOS based on the DAC configuration, the SRC doesn't do nothing to that.
If the DAC has an 8x OS mode for 44.1/48kHz, then it will be OS. It might have an 4x mode for 88.1/92kHz and a 2x mode for 192khz... or it might be 1x for all the above - it's all depends of the DAC.
