Hello
I have a homemade bass reflex loudspeaker using Dynaudio 17W75 woofer and D28 tweeter, there is a passive 6db crossover and I will change it for a passive bessel 12db crossover.
I can put the center frequency of that crossover at 2000 hz but I was think to go lower at 1600 hz, so less high would goes into the woofer and also because the tweeter do have an excellent transient response and also because the soundstage are mostly in the high frequency harmonics so the tweeter will do that job best.
Is it a good ideas, any suggestions ?
Btw, I will also ad a Zobel network, and both the tweeter and the woofer can run at 150 watts, and my amp are 60 watts.
Thank
Bye
Gaetan
(Here is the frequency response graph of the Dynaudio woofer and the tweeter.)
Thank
Bye
Gaetan
