About amps power consumption
Joined 2009
Hi !
to have an idea of the real power of an amp I have always been told to look at the power consumption on the rear
But ,,, these are the ratings of the original transformer of an amp
31V-0-31V (3A each) and 18V-0-18V (O.4A each)
and 600W is what is reported on the back as the max power consumption
it is about 1/3 of the value stated on the official specifications (!)
Does this value refer to short circuit condition ? 🙄
How can this be possible ?
Thanks and regards,
gino
Power = energy flow per second
So you can have a low average power, but a high peak power. Manufacturers of amplifiers are in a competitive environment and consumers who buy amplifiers because of their power rating encourage manufacturers to state high power ratings - which they can do if they state peak power instead of continuous average power.
I was asking the same questiom the other day and the answer was :
see if you can measure transformer's core section.
I did, and it was 2,5 X 3 cm ; on the back of the amplifier it was stated 310 W
max consumption.
The reply was : it can hardly produce 30 W 😱😕
Does 600W come from RMS mains voltage multiplied by RMS mains current? Not a sensible calculation, as they are different waveforms, but you can't assume that whoever decides what to print on the back panel understands electronics.
From what I understand the 3A are in the secondaries .. not in the primary
So I should multiply 3x31x2 (leaving aside the low voltage windings)
But this is what Talema sells as a 200VA transformer ... not a 600 one
You say you can't assume that whoever decides what to print on the back panel understands electronics
I am pretty sure they understand electronics very well
It is me the confused one ... unfortunately
I think I will look at the size instead
I see that the size tends to be similar for similar VA
Regards,
gino
The max power comsumption is forcibly the level at wich the amp s
main fuse goes open circuit...
In the OP exemple there must be a 2A or so main fuse that will
be fused at about 600W input power , whatever the cause of such high
absorbed power , be it the transformer that got two shorted
windings or the amp outputs that are shorted.
max consumption.
Actually in cheap amps the transformers and the power caps are usually undersized and low grade types
Unfortunately is a key section for performances
Buona serata 😀
gino
The max power comsumption is forcibly the level at wich the amp s main fuse goes open circuit...
So my method was plain wrong
I will keep this in mind. Thanks a lot !
Regards,
gino
