I have a slightly different problem, but it concerns hum.
The setup is such; internet radio into a mechanical switch , the switch output goes to a Rolls SL33B limiter.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The limiter output goes into an FM transmitter.
I didn't have a the hum until I installed the Limiter. It is fairly low level hum. If I touch both the FM transmitter and the limiter with my hand the hum is reduced considerably (good enough), but a clip lead shorting the two doesn't do the same as me touching them.
Each of the units internet radio, limiter and FM transmitter, have their own power supply. All are switching type power supplies. Would it help to run everything of of one supply?
Any ideas how to eliminate the hum?
