Greetings Everyone! I've been lurking for a few weeks while contemplating the design of a new sub for my home and thought I'd jump in and ask a few questions...
First off, I've read somewhere that polypropylene subs are less than desirable since plastic can flex and creep over time... Like a speaker cone made of tupperware. What are your feelings on this?
My intended design is an NHT 1259 (8 ohm) mounted in a 50 liter sealed box with "heavy" fill as recommended by BassBox6. According to BB6, this will give me a Qtc of 0.86 and an f3 frequency of 36.14 Hz. The 1259 has a polypropolyne cone...
Also another question... I will be driving this with a parts express 300-794 plate amp (150W into 8 Ohms) and it will be situated in a 14' x 14' x 8' room 12" from the left wall and the back of the sub about 5" from the front wall. Is this f3 too low based on how much room gain I will expect? I'd say the room is acoustically neutral as a guess.
The sub will be used for both music and home theater. The receiver is a JVC with a subwoofer output that (if I remember correctly) is crossed at 100 Hz. The main speakers are Boston Acoustics Lynnfield VR's (750's I think). Based on this description, what do you all think?
Thanks in advance for the input! Since this is my first speaker-building project, I want to make sure I do it right!
-Joshua
-Joshua
