do you still hear voices when the cut-off is at 80 hz ? would i be able to locate the sub ?
Q qguy Member Joined 2005 2007-12-05 11:05 pm #1 2007-12-05 11:05 pm #1 do you still hear voices when the cut-off is at 80 hz ? would i be able to locate the sub ? ••• More options Share crippledchicken Member Joined 2003 2007-12-05 11:45 pm #2 2007-12-05 11:45 pm #2 alot depends on the rate of slope on the crossover 12/24db etc. as well as build quality, of the crossover from my experiences. ••• More options Share M MaVo Member Joined 2006 2007-12-06 12:09 am #3 2007-12-06 12:09 am #3 i would say you can locate it. males voice lowest formant is around 100hz. so the sub will play it with maybe -6db, depending on the crossover etc. ••• More options Share D Daveis Member Joined 2003 2007-12-06 4:10 am #4 2007-12-06 4:10 am #4 24 db/octave at 80hz works well for me. But I have two sub woofers equidistant to my main listening position. I usually start my sub crossover point where the main speakers are naturally -10db down. ••• More options Share Show hidden low quality content Status This old topic is closed. If you want to reopen this topic, contact a moderator using the "Report Post" button. Share: Facebook Twitter Reddit Pinterest Tumblr WhatsApp Email Share Link
