I'm wanting divide BCK on TDA1541A with 74HC4040 as outlined here;
http://www.diyaudio.com/forums/digital-line-level/203511-any-good-tda1541a-dac-kit-4.html post #32
I can get either 74HC4040N or CD74HC4040E, Clock frequencies are 98MHz and 35MHz respectively - which is the correct IC for the application?
Many Thanks,
Shane
Many Thanks,
Shane
The clock frequency on the respective data sheets is simply stated being either 98MHz or 35MHz.
Formerly Farnell | Electronic Components Distributor | element14 Australia
this link should work, top two chips on the page - scroll down an inch.
Thanks,
Shane
Thanks,
Shane
