5v supply amp modules?
If you want to run a RPi Zero, then this is possibly one of the best options. You can select mono output in the RPi software. You'll need a good powerbank:
https://www.infineon.com/cms/en/product/evaluation-boards/kit_40w_amp_hat_zw/
Alternatively, I use a number of these in BT speaker builds (stereo, not mono):
https://www.aliexpress.com/item/329...ab!66517632763!sea&curPageLogUid=28eEP4PAPinK
Here's a mono amp:
https://learn.adafruit.com/adafruit-max98357-i2s-class-d-mono-amp
Apart from the RPi solution, I'm guessing you'll also need a 5v BT module:
https://www.aliexpress.com/item/100...00026884840784!sea&curPageLogUid=K5KdaQvccNZ3
