Yesterday I finished making changes to my all-differential PP amp. One of the changes involved increasing the grid stopper on the input (non-grounded) grid of the 6SL7 LTP splitter, from 10k to 200k, to take advantage of the Miller effect and limit the high-frequency response. The intention is to have -3dB at 40kHz.
Another change was to add 1Meg local feedback resistors from the 6SN7 driver plates to the splitter plates and to reduce global feedback by 50%.
The ovedrall gain is now a bit higher but 50Hz hum has become audible, whereas before it wasn't. I haven't changed the layout significantly. My power transformers are toroids and shouldn't be radiating significant hum, AFAIK. I wonder if giving the IP tube a big stopper may have increased its senstivity fo hum? Or maybe I should have increased the stopper on the grounded grid too, to preserve PSRR? Any ideas?
BTW, there is no connection to ground at all, because I don't have a 3-core power cable. That sounds pathetic, I realize, and I intend to remedy it but, up until now, it hasn't made any audible difference.
