For Sale 46 Amp from Japan
Things you have for sale.
This is a lovely sounding amp. I have installed Finemet c-core transformers . There is a switch for 4 , 8, 16 ohms . Copper top line Jupiter coupling caps. Western electric 717 input tubes
I made it look great . 1 glories watt. Dead quite. This is a 100 volt amp will have to be ran with a step down transformer , or a vary-ack .
thanks Rick
1325$ and shipping
Reactions: zimbida
thanks Rick
1399$ and shipping
thanks Rick
1399$ and shipping
The cutout on the rear panel for that 'lytic looks tacky. At least get the cuts straight and take a file to the rough edges.
Hello,
The cutout should be made a little bigger and the plastic '' strip '' already there should be replaced by one a bit longer so can create a protect one piece of protection sleeve. The moment you will cut yourself during lifting this tiny amp you will probably let it drop.
You get some greasy fingerprints for free on top of that.
Greetings, eduard
