41Hz.com have updated their site http://41hz.com/
If you look at the overview page, you will see that they claim the AMP8 will do 2x1000W into 2ohm (I'm going to assume ~600W low THD). Unfortunately they are out of stock, but I'd like to see if this will work for what I want before I order...
Now, they also state that the amp can be bridged, but they do not state the power when bridged... I'm guessing this would be 1x2000W into a 2 ohm load (or would it be 4 ohm)? I know there are a few people here that run an amp 2, so I was hoping to hear how this amp works when bridged.
Basically, I want to drive 4 x 8ohm subs, they are each rated for 500w but I plan to run no more than 200-300W into each. The amp8 seems perfect for this.
Finally, for the PSU I plan to use 1 x 1500VA toroid, plus 2 x 10000uF caps for each rail. Each rail will be 65v DC. Will this be enough, or will I need more capacitance or a bigger toroid... Bare in mind this will be used for PA.
As for heat, I plan to use a 2U PA amp chassis with actively cooled heatsinks... This should enough I would have thought? Does anyone know how many output FETS the AMP 8 uses (8?)?
