I'm having a hard time making the transition from premade audio processors to PC based processing. I'm just not very familiar with some of the terminology. I'm looking for a sound card/software that will allow me full control over a 4 way actively amplified system before the signal leaves the PC. The trick is, I need highly customizable crossovers, preferrably unlimited frequencies, n-th order filtering with options for filter type (bessel, butterworth, linkwitz riley, chebyshev, etc.). Then I need manual time alignment. My understanding so far is that time alignment might be the tricky part for most sound cards as it requires internal routing? I'm a little hazy on this. Auto time alignment would be a nice bonus, but not required. Lastly, I need at a minimum 1/3 octave graphical EQ per channel. Parametric would be a nice bonus, but not necessary. I've got 8 channels of amplification right now, but I'd like the processing to be embedded on the PC for easy adjustment. This would be going into a carPC, so tweaking settings on the amps would require getting in the trunk.
I won't say that money is no object, but I could swing up to $300 for a quality sound card without being too worried. My amplifiers are unbalanced RCA. No digital/optical inputs. Therefore, RCA connectors would be ideal, but 3.5mm with an adapter would work too.
I've played around with audiomulch on my desktop PC, but I don't have an active PC speaker system to play with it too much.
So, does anyone have any recommendations? Is anyone else running active processing via PC? If so, what works? I figure you folks may have already come up against these problems and found a good solution. What do I need in a sound card that will allow this system to happen?
