the fets are playing a part as well as the opamps, really...
the TI opamps are tighter... really im not imagining it.
the fets play a BIG role ,ive had irfz44, irfz48, smp60n06, in each amp and hands down the 3205 is best out of these.
faint bass notes in the background are more pronounced than before...i usually listen to the same 4 cd's every week then change when i get bored with them, so im familiar with the bass in the songs.
thats why i went ahead and did these two changes without question, so the other 3 amps are half way there.
i already tried the cap change for this amp and it lost volume, so changed them back.
Perry im glad you asked when it clips...
its stronger throughout all levels, especially when it goes into clipping, it just goes crazy...when the other 3 start to level off and flatten, the loud one is like its shouting at the top of its lungs but is loud and clear, strong and hard and keeps climbing... still damped fairly well....i havent found its limit yet because my electrical goes first...50ah batt, 65 ah alt. (for now)
im pretty sure the other part is the gain, i was taking a look at the pdf's for the current gain of the MPSU vs BD909/910 vs 2n6488/91...take a look if you have a chance, i dont know if im reading it right.
the gain is only a little bit above half way... the others were at 80%.
in another post i tried two amps at 8 ohms...this one amp alone at 4 ohms is way louder....it really is louder, maybe not more powerful...but louder.
really, no BS...im not kidding
the only other things ive changed are the pots, 25v tantulums and the 4 big grey 6 ohm resistors to 5watt 5.6 ohms...
i need to check the pot one more time to see if it is a fast rate or a slow rate pot..and also which location i put them in, do to stem length.
( i didnt know rates existed until the salesman told me, i thought a 50k pot was a 50k pot)...this pot wasnt changed at the same time.
oh...and im not getting disallussioned by the deck volume.
for the stripped holes i used some screws with a wider pitch and thread locked them into place for right now...almost all of them were stripped or were on the verge of being stripped.
i used cut strips of kapton on the securing rails..i will never use double sided tape again !
