4.5" vs 6.5" Trade offs
I've been lurking and browsing a lot of the online plans in hopes of taking a speaker project just for fun.
I the look of designs like the Milena/Dimitri Fonken Floorstander, etc. I figure I might at well build something 3-4' tall and not have to worry about stands. It'll be a while be for a pick a design. I first have to decide on size.
Look at specs on drivers like the fe127e and fe167e that some designs I like use, I'm curious about the trade-offs between 4.5" and 6.5".
Benefits I can think of with a 4.5" --
Cheaper (but $20/driver is chump change compared to building effort)
Less wood to buy for smaller enclosure. (might be more than driver cost difference)
Higher WAF of smaller enclosure.
More places they'll work in the house if I decide to use them in a different room.
Benefits I can think of with a 6.5" --
+3db efficiency
about 1/2 octave deeper bass.
So that's what's intuitive to me. Are there other things? Would the sound from a 4.5" be clearer at the expense of given up bass (or using sub)?
+3db efficiency
Id say depends on listening habits, room size and amplifier power..
If you really like it cranked then the 6'' or larger drivers are going to serve you well, especially if crossed over to a sub...
If you listen more intimately and require just medium loud volumes at times, then I'd stay with the smaller 4'' ish drivers. Nicer mids and highs than many of the larger drivers, and if you add a well designed sub to bring up the lower freq you'll have a very nice hard to beat system.
So I guess my vote would be if were talking Fostex ,and your not into high spl ( wrecks your hearing anyhow) I'd stick with the smaller drivers for that sweet midrange, Fe108ez, 127, 126 etc.. And then if you want, add a sub to fill in the bottom...
Dave
Dave
IMO fostex drivers are un-listenable without a BSC circuit. With that in mind, your going to loose 3-6 dB efficiency in the mid range. I'd go with the FE167E if your using a low powered amp. Parallel a 6ohm resistor with a 1.5mH choke. Then wire the component pair in series with the driver.
The only exception to the BSC I've had with fostex drivers is using an amp with a Zout of 8ohms driving the FE167E. A Zobel was added to bring the impedance rise down a little. While the lower mid range isn't quite balanced with the rest of the mid range. It is still for the most part a pretty good sounding combo with a surprising amount of bass for a full range driver.
http://www.zillaspeak.com/fostex127eSSB.asp
scroll to the bottom to read my thoughts comparing the fostex 127e with the 168s (old style with wizzer).
I noticed no real difference in loudness from one driver to the other. Maybe the 167e is more efficient than the 168s?
Thanx for the response Mr. Zilla. I looked at your pictures. I'm thinking of building he speakers to fit against the wall on either my of the fireplace in my den in much the same fashion as yours. That's why I was looking at the Mileva design which looks similar in dims to yours. I'll have to take and post a pic of where I want the speakers and post it.
For what I want to listen to, somewhat sparse but bright acoustic music-- mandolins, fiddles, acoustic guitar and bass, bluegrass, old-time folk and country (not modern nashville country rock), vocals like Peter Rowan, Emmilou Harris, Gillian Welsh, etc. Oh, and same blues and jazz maybe with a warm electric guitar sound (Ronnie Earl) and a bit of Hammond organ or piano. And stuff like the Waybacks and Hot Club of Cowtown acoustic with a fuller sound, traditional/jazz blend.
The larger drivers won't have the midrange magic of the smaller drivers, but will have better dynamics.
Myself, i'll always go for the smaller driver.
With wall placement, a wide cabinet like Mileva means that baffle-step is dealt with acoustically, ie the speaker doesn't have 4 pi space to radiate into,
dave
dave
Here's some pics of my inverted fe108 BIB cabs, taller than you may want but sound very nice and easy to build..
Dave
Dave
Having played with a few drivers my mind is firmly in the camp of 4 to 5 inch drivers if you want real magic, but with the caveat of using a matching sub. Good smaller drivers just have a mid range magic that is quite amazing and they follow a complex waveform in a way no larger driver can. 5 inches is probably about as big as you can go before the mids start to loose something. Additionally a good small driver can actually stretch well into the upper freqs so a tweeter is not needed in most cases.
Larger drivers have more dynamic impact I guess but in general I would trade this for clarity and mid range finess at any time.
Incidentally it is possible to use an active high pass filter on the driver so as to block freqs below say 50hz, this is no hardship as the sub will cover this anyway, but it will relieve some stress of the drivers making for an even cleaner mid range and much higher power handling and thus more volume if that is what you are after.
Zero One said:...Incidentally it is possible to use an active high pass filter on the driver...
When you say active high-pass would that imply that it's in the line signal before power amplification? That's as opposed to just some Ls and Cs (and Rs if need be) between speaker terminals and driver.
I don't have as much experience as many of the other posters here, but I will offer my "observations".
The smaller drivers (specifically the 4.5" fostex I have heard) seem to handle the very high frequencies with a finesse that I like. Many tweeters and supertweeters and even the ribbons I have heard just don't seem to have the airy sound and ambient energy that these FR drivers possess. By Themselves, they don't have ground shaking bass output so a sub might be in order if you like that kind of thing. The ability to work in the vocal range and the high cymbals etc is just lovely with the smaller drivers. I imagine from reading that the treated drivers are that much better. I have only heard one pair of modified 126 drivers (not Dave's) and they were just about the sweetest sounding thing ever.
I liked the combination of this driver with another unit that put out a bit more dynamic output. Two FRs in this case, but the Fostex was obviously handling the mid to high end and the other driver was going mid to low end just by their character. Bear in mind there was no x-over involved so you have to keep that in mind.
The larger drivers often need a little help at both ends. A supertweeter might help get closer to the smaller driver's abilities in the high end, but the larger drivers (6.5") still won't put out 30hz at 100db very easily. If you like that bottom end, you will still need a sub so now instead of 1 helper, you are looking at two and more x-over.
If you don't need the house rattling bass, a lot can be gotten from the smaller driver in the right cabinet. A WHOLE LOT.
Just my thoughts on it.
Take care,
Robert
Take care,
Robert
Zero One said:Larger drivers have more dynamic impact I guess but in general I would trade this for clarity and mid range finess at any time.
And woofers with simple active hi-pass* can give back much of those dynamics and produce bass most full-ranges would never hope to.
* (ie PLLXO or better yet, a suitably choosen coupling cap)
dave
musgofasa said:I don't have as much experience as many of the other posters here, but I will offer my "observations".
Take care,
Robert
If your project plans definitely include stereo bass drivers, then another quite special driver (although it certainly has X-max limitations) is the Fostex FF85K - particularly when utilized in a OB configuration.
XO around 150Hz or so in sealed or resistively ported enclosure, or an octave or so higher in OB, this little guy can give some high-end tweeters a run for the money.
What to drive 4.5" fullrange
Hopefully my last follow-up question on this thread.
What's the preferred amp to drive these 4.5" speakers?
I'm just reading specs now but they don't look quite efficient enough for lower powered SETs? If they aren't supposed to sound good with SS, would you use PP tubes? Or maybe a tube pre with an SS amp?
Hi kvk,
I listen to lots of folkish and jazz music also. The smaller drivers definitely do have the midrange magic over the larger drivers.. Anyhow I use the fe108es drivers which are 90db with a Decware Taboo 6w SEP amp, and it will get about medium loud in volume.. The 126 driver will go somewhat louder still, and the larger Fostex will get very loud with that same 6w...
As to the preferred amp Id say Tubes are where its at
Depending on how much money you want to spend there are some regarded tube amps in the higher watt class,the Decware Torii or the Jim McShane redone Citation amps, plus the McAlister amps are even more wattage for the money spent..
I would very much recommend that if really loud volumes are desired for most listening, or for parties and such then you want the larger 8'' drivers. You'll still get very good sound that will impress your ears in the right cab... Also I've never heard the larger 6-8'' AER or Lowther drivers, but I would imagine that they would have the same or better midrange magic as the smaller Fostex drivers.. Dave
Re: What to drive 4.5" fullrange
A good tube preamp could be a great addition
Depends if you are looking to DIY the amp or not. I have mine driven with an LM3886 based chip amp, which I think is great. I listen mostly to 60s and 70s rock, jazz, classical and some modern rock and metal. Not having passive crossovers makes full rangers a very easy load to drive, and most amps will do just fine (40W or so should be plenty). Before the chipamp, I had a very unremarkable MOSFET based amp, which is now powering the subwoofer in that system.kvk said:
DaveCan said:...redone Citation amps
Please don't make me cry. My Dad put together a full HK Citation line, tuner, preamp, amp in about 1960 plus or minus a few years. About 20 years ago, he was confvinced old tube stuff was junk but I couldn't convince him otherwise. He tossed it all for a cheap RatShack receiver.
I had told him to give it to me if he ever wanted to get rid of it but he forgot. If he had given it to me, I would have spared no expense restoring it to cherry :-( :-( :-(
If I was you ...I would go small 4-5" . 108 etc...& find a desighn & driver combo that runs no filter's. If the driver is behaved enough this is the ultimate for it's scale in the heart of the music. i run multiple OB systems, with everything from 45 to PIM, 300B PP into hybrid OB using SEAS 5". & so on. Filters sure enough do there job,...but ..Filterless FR is something to be in ah of when it comes together. any amp is fine..but I am severly tube biased for reason I think they just do the job of music repro better than anything. Especially DHT SET. SET into 108...oh boy PP 6550 in triode or 2a3 PP would be the swell also. Heck I even like a 45 into small drivers for low volume stuff. mmmm 45 & filterless FR..My ultimate. Yep, please try the little critters if you don't need big scale, then you can later build a hybrid OB or something similar based on this little FR driver & have all kinds of fun.
J & G
J & G
I'm using an Emotiva LPA-1 SS amp to drive the FE-127eN in Fonken cabinets with ~3db of BSC and actively xo'd to a sub @60hz and I am extremely happy with the setup. There are also many "T-amps" that reportedly work with well with the various Fostex drivers. I have an Amp6 Basic which sounds good, but I still prefer the Emo amp.
kvk said:Hopefully my last follow-up question on this thread.
- Full Range
- 4.5" vs 6.5" Trade offs
