If this is a high output design, FaitalPro makes a number of suitable mid/mid-woofers with significantly high output capabilities.
Otherwise, if you aren't looking to shake the house down, ScanSpeak makes some excellent mids and mid woofers.
There are many possible choices. 6.5" prosound mids from all the reputable European manufacturers will work. Crossover around 350hz and 2khz.
This BMS is one of the best.
Overview
Will this be an active system?
Faital Pro 10PR410 is a perfect match with Beyma TPL-150H. Faital Pro 8PR155 is also another good choice but lacks some dBs. Beyma 12P80NDV2 is also a very nice driver if you can get along with beaming issues
Thanx!
This one looks like a woofer
it's actually a midbass/midrange. it's a very good piece of speaker
For this midrange size we need a bigger woofer.
15 or even 18 inches
Woof woof, now you're talking.
You can't play real bass with 12" (isn't that a midrange?)![]()
Would like to see the crossover be like, any different designing between the Beyma vs a CD?I'm planning to build a passive system. .
18sound 6ND430 4ohm should keep up with your woofer once you factor in baffle step compensation. If running active, 8ohm version is probably better (lower distortion from your amp).
