I have a 3pin Molex pcb contakt:
26-60-4030 Molex | Mouser Sverige
But I dont know how to find the female WITH cables, at mouser.
Anyone can help?
Anyone can help?
Open the associated datasheet and select your preferred mating housing (the plastic adapter). Purchase also the proper metal contacts to crimp to the wires of your choice. Finally, enjoy the adventure of crimping and assembling.
Electronic shops near me have them assembled with 20 cm cables.
Conector Molex Femea - 15 Contactos | Aquario Electronica
Forgott to mention that there is 3,96mm space between the pins.
Do I need a special crimping tool then or do I solder the kabels?
I crimp mine with small pliers and it has always worked out fine. The Molex crimping tool is quite expensive.
63828-0300 Molex | Mouser
Molex Connector Part Number - 08-50-0008
I have been able to purchase a ratchet crimping tool for $25 on Amazon. Once you line it up correctly, the crimp is beautiful. Looks like KK 396 series for the Molex connector.
Squeeze the lugs a bit with pliers first and then solder the wires.
Insert / Test if they fit the connectors first before soldering.
- Design & Build
- Parts
- 3pin Molex female?
