Well, I've pretty much finished designing my preamp/crossover and am just waiting for a few parts to begin building it. My questions is, I'm making my crossover point 600Hz, but at 600Hz, neither the high or the low is being attenuated, correct? Therefore there would be a +3dB increase at 600Hz because of both the low and the mids reproducing it, correct again? In that case would it be a good idea to attenuate by 3dB at 600Hz? And since I'm using a 12dB per octave crossover, it would be even better if the attenuation rolled of at the same, right?
Or would I be better off attenuating less then 3dB? I don't know if in reality it ever does achieve the +3dB bost, since the mids and woofers and physically quite a ways apart (relatively speaking that is).
