Hello. I'm an amateur musician and new to electronics and require some guidance. I want to learn about voltage swing requirements for a vacuum tube, specifically how to determine the amount required to drive a power tube. I am also unclear how to determine the amount of voltage swing a driver will output.
I assume these things can be derived from datasheets but I'm unclear what google searches I should be doing to find this information.
I have ordered the books written by Morgan Jones and Blencowe and should have them soon. Hopefully they won't be beyond my understanding.
The paragraph or chapter titled "How to construct a loadline" will show you how to use the graph on the datasheet to read the input and correlate it to the output of the tube in question.
kind regards
Marek
kind regards
Marek
Personally, as a musician myself, and with the only developed skills in math coming from a summer school rapid cal class when I was 14, I found the old military training manuals the most natural place to start. (ie. the least brain pain) with every section followed by a few questions that got me to check back and gel what I'd just read.
The N.E.E.T.S. series was one of the ones I used, the Tubes section is posted below and links to the entire series linked HERE.
It should keep you occupied until your orders come in. Happy Trails !
