I've decided to build a two channel power amp based on 3*lm3886 for each channel.
I've previously built a simple lm3886 two channel (the kit from BriantGT) with just a normal Alphs pot and just one input. This thing sounds amazing, but it lacks the power to drive my Pioneer HPM-110. Bass dont seems as controlled as it is with my Pioneer A-676 amp, especially on higher listening levels.
My plan is therefore to buy a HLLY DMK-IV to use it as a pre-amp, DAC and headphone amp. This will be combined with the above mentioned power amp.
The PA150 looks like something I could use for this project. I just cant find anywhere to buy them. There's a few on ebay that looks similiar, but I'm not sure its the proper ones (I've a hard time to trust chinese companys).
Do you know if there's any legit PA150 pcbs on ebay, or do you know where I could get two? I do not want to put an order on just two pcbs cause it'll get to expensive. Maybe one of you got two spare ones from a previous group buy? Or do you have other suggestions instead of the PA150?
I'm also not sure what recrifier to use. Will the recrifier from my previous amp work to drive 2x3*lm3668 with the simple modification of adding more/bigger caps? Schematic can be found here:http://chipamp.com/images/ps.gif or do you suggest something else?
Thanks / Maxhax
Thanks / Maxhax
