2SK301 as alternative to 2SK170?
I have some 2SK301 jfets by Matsushita (Panasonic), datasheet attached. Class R, 5 to 12 mA IDSS. Would they be suitable for use in a unity gain buffer like the Pass B1?
There are differences in electrical characteristics compared to 2SK170, but I don't know how significant these differences are. For example, gm (Yfs) is lower than the 2SK170 - would this mean more noise at unity gain? The noise figure (NF) is low, but is only given at 100Hz, not 1kHz as for the 2SK170.
I would appreciate some advice, not being knowledgeable on jfets. If I am comparing chalk with cheese, I will assign them back to the drawer where they have lain for many years.
Sorry, I should have said "alternative", not "replacement" in original title, i.e. to use in a new circuit.
And for Rg=100k.The noise figure (NF) is low, but is only given at 100Hz, not 1kHz as for the 2SK170.
100Hz is good. The noise always goes up below some low frequency knee and too many parts hide this by specifying noise at 1kHz or higher.The noise figure (NF) is low, but is only given at 100Hz, not 1kHz as for the 2SK170.
[/B]
- Design & Build
- Parts
- 2SK301 as replacement for 2SK170?
