What is it used for? If it is turning an LED or relay off and on, you can use just about anything. If it is in a low noise preamp signal path, maybe you need more selectivity.
I haven't looked anything up, and 2N3906 might work fine. But i will warn you, all the 2SAxxxx transistors will have the legs in different order from the 2Nxxxx tpes. You can swap them, but will need to turn the part sideways to get the legs in the right holes.
