> Why doubt the new Russia so?
SY is comparing to TungSol. Classic USA tube making was very sophisticated: it supported a significant special-metal market and RCA GE et al knew a LOT about tubes: how to make them very good (and how to make them very cheap if that's what was wanted).
TungSol was started JUST to make Big tubes BETTER than the best from the Big Brands. The early TungSols are amazingly good tubes. And they did find a niche as electronics expanded through the 1950s.
The "new good" 6550 has been tried by organ players and apparently stands up well in Leslie amps which work their 6550s pretty hard. The Hammond has a simple tone structure, so any great change in 6550 sound would be noticed. The Leslie works the 6550 hard, but not to its voltage limits; how it will hold up in high-volt uses, I dunno.
I think a triode-strapped 6550 makes a great SET. I have not heard a 2A3 since they were common in old radios (they were not that common then) so I can't say if a hot-filament sounds better than a unipotential cathode. Considering the price difference, the fact that 80% of the amp can stay the same for 2A3 or 6550, and the fact that you have to ask, I say try 6550 but leave room to have a 2.5V filament supply and old-style socket.
When you get into P-P, I think many of the difference cancel. Quite bent tubes can make fine P-P amps.
As Jason says, the 2A3 is such a perfect triode that it was cloned over and over again, usually with heater-cathode because that is so much easier and nobody saw a problem with that until the 1990s. Several TV V-Sweep tubes are pretty-near a 2A3 plus a small volt-amp triode. 6EM7 is a 10 watt 2A3-ish big triode plus a Mu=60 triode much like 12AT7. Two of these could make a fine P-P amp at the several-watt level. 6EM7 and similar TV V-sweep tubes are mostly so darn cheap that you could use four and get enough triodes to have many-watt PPP plus fancy driver. (Take the B+ up to the tube rating. Adjust load impedance tangent to the Pd line at B+ to get the most power within the plate dissipation rating. This also maximizes damping. You can take a little more power by lowering load impedance and allowing the load-line to rise a bit above the Pd line: this is not fatal for speech/music duty.)
