Hi all...
I want the DAC im designing to support 24bit, but i want to also use the TAS3001 (kinda DSP) which only supports 20bit.
Im not worried about loosing the 4bits of audio data.
If i make the SPDIF recv (DIR1703) output in "24bit, MSB first, left justifed", and put the TAS3001 in "20bit, MSB first, left justified", will it work the way i want?
As in the TAS3001 just ignoring the 4 least significant bits?
If not, is there another way i can do this?
Thanks.
Thanks.
